Ac removal or another solution
So I've ran into an conundrum . I am trying to take the wheel chair lift out of my bus but it seems that an AC unit was installed right under the lift . it is blocking the bolts on the underside of the lift. I was able to use a grinder and get at a few bolts cut out but couldn't grind a few . I am thinking of either dropping the a.c. and then trying to put it back in place once the lift is out or take it out completely. The bus has two a.c. units . one in the front and one in the rear and the rear one is really big and would be in the way of the planned elevated bed.
Does anyone have experience with two a.c. units ? Is it worth it having both ?
