Old 04-19-2022, 04:09 PM   #1
Chassis: IC CE300
Engine: 466DTE
Anybody Have One of These?
Hello -
Has anyone had experience with this AC unit, like used as a driver AC unit not necessarily for cooling an entire bus?
Pnutty is offline   Reply With Quote
Old 04-19-2022, 06:02 PM   #2
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Originally Posted by Pnutty View Post
Hello -
No experience with it. If it doesn't have outside air going to the condenser it's not going to work well and I cant see if it does. If it does use outside air to cool the condenser then it could be total junk but it could be functional. It isn't likely to be very efficient though as it appears to be one of those super cheap product sites. $800 for a good mini split and you'll be happy. If that's too steep, maybe someone will be along that's tried this model.
Either way, good luck
HamSkoolie is offline   Reply With Quote
Old 04-19-2022, 07:36 PM   #3
Chassis: IC CE300
Engine: 466DTE
Thanks very much @hamskoolie. The unit mounts on the roof/outside. I have a mini split, yet to install, looking for driver AC while driving. Thanks for the response.
Old 04-19-2022, 09:09 PM   #4
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
So it's a split system, does it have a rating of any kind?
Rwnielsen is offline   Reply With Quote
Old 04-20-2022, 05:25 PM   #5
HamSkoolie's Avatar
We're doing two 9000 BTU mini splits. One in the bedroom and one centered over the windshield. Either is rated for far more space than the inside of a 40ft skoolie.
The one over the windshield will be used while driving. IF (we don't anticipate due to door remodel and spray foam) there is too much air exchange with the outside while underway then we will hang a curtain to retain cool air in the driving and Pax area while underway.
9000 BTU should cool 400 SqFt in a home...with 8 ft ceilings. That's 3200 cubic feet.
Our skoolie will be 7.5ft wide and 39ft long with about 6'3" of headroom. So 7.5 x 39 x 6.25 is 1828 CuFt..... But then you have to adjust for four wheel wells, the rear engine compartment, etc. but let's just go 1ith 1825CuFt to make it kind of simple.
That's only 57% of the space 9000 BTU should take care of. But it's a long way from the front to the back so we went with one at each end for some redundancy as well as to allow the front to provide cooling while driving and the rear to cool the closed off bedroom with ease in even the most severe heat.
driverac, rooftopair
