The thread title being 'Appliance Power Math', this might help (and I think is posted elsewhere in this forum, available with a search), fridges use induction motors, which draw a huge initial current, then afterwards draw very little.
So when calculating inverter or battery sizes you need to be able to support the inrush current (8 amps on my dorm fridge) as well as the normal draw (about 3 amps). The 'normal draw' is periodic, and probably can be calculated from the energy usage sheet that comes with the fridge, like other folks above have done.
Every once in a while the fridge turns on, and for a few seconds draws lots of current, then settles down to it's normal draw. An amp meter (clamp type meter) with a max or 'inrush' button will help you capture the initial surge.
You can also buy pretty cheap devices on Amazon that track watt usage. I bought one, but never bothered to experiment with it.
