Originally Posted by rossvtaylor
Thanks for the faith! I hope it works well for you. I should have clarified that the fan and ignition circuit run off 110-120VAC. The popular cheaper units run off a couple of D cell batteries. But my builds always have AC power available.
In my electrical system design writings, I always promote 2 inverters...a small one for things which you might want to run all the time (like chargers and clocks and the water heater) and a larger one (with a remote on/off switch panel) for higher draw devices and appliances...like the induction cooktop, coffee maker, tools. I like your plan and will follow along as you implement it.
True, these run on 110! I had a dinky 500 watt inverter specifically for the Camplux in my original design, and ended up pulling it out because I have plenty of battery capacity and will keep the main inverter running 24/7.
I still haven't connected the dedicated fridge inverter for the same reason.
