Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 09-08-2021, 09:53 AM   #1
T-Bolt's Avatar
Engine: DT530
Best place to get AC parts?
My bus came with 2 Carrier AC units. They were empty when I got the bus and located poorly so they were temporarily removed. Now I would like to reinstall at least one up front but parts will be needed.
The evaporator is in great shape but some of the external parts will need replaced. The fans on the condensers do not work and the dryer is rusted out.
Where can I get parts without breaking the bank?
https://eternitybus.com
T-Bolt is offline   Reply With Quote
Old 09-08-2021, 10:15 AM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Look on Facebook
Ask around here for parts that others have taken out. Think about buying parts new for years of trouble free use.
I have found bus ac system parts on Facebook marketplace and Craigslist
Also salvage yards and scrap metal yards.
William
Old 09-08-2021, 12:21 PM   #3
condenser fans.. if none of them work.. its more likely the relay.. its the 'CR' on the evaporator control board (it may still be in the bus unless you pulled it.. the board). otherwise I use SPAL branded fans.. the condenser fans pretty much match up to standard High performance High CFM models of standard makers. . SPAL is high quality and lasts well.
Transartic sells OEM carrier style parts if you need things like plastic covers, blower assemblies etc..
Line and hoses i always email ProAir LLC or if you have part numbers you can call their parts department directly with part numbers (you can look up actual ProAir part numbers for fittings, hose etc on their website)..
not sure what all you need external wise? but I probably have some of that stuff laying around..
COmpressors I always buy Genuine Sanden.. if I have a pic and part number of an existing compressor I can cross it up for a genuine Sanden which can be bought online.. I always have a couple spares on the shelf in my garage if you need one fast.
Old 10-22-2021, 11:00 AM   #4
I have 2 units in my bus that I am removing. The rear blows cold. I think the frt had a freon leak at the expansion valve. You are welcome to anything you need. I am in Central Ohio
Sbitner is offline   Reply With Quote
Old 10-22-2021, 11:43 AM   #5
let me know if you need the freon recovered out of the systems i have the equipment to suck it out
Old 10-22-2021, 12:51 PM   #6
The frt system was empty, There was a loose crimp at the expansion valve. The rear system is fully charged though. Where are you located?
Old 10-22-2021, 01:25 PM   #7
im in the grove city Ohio area
Old 10-22-2021, 05:18 PM   #8
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
This site below (a) helped me figure out what I actually needed, and (b) got me the parts I needed when the local hose rebuilder could not.
Then I got my own AC hose-fitting crimper (for beadlock fittings) on eBay (deluxe for like $120 or something) and did the hoses myself. That was the best way, because then I could clock the angle of the 90 fittings correctly on the end of the hose after I ran it through the body.
coldhose.com
(it looks like they just redid their site, so hope it is still as helpful)
I found the cheapest hose on ebay (genuine Goodyear) and at Summit Racing, but it took 2 or 3 sources to get me all the sizes I needed.
Look at the Sky; look at the River. Isn't it Good?
Old 10-23-2021, 04:39 PM   #9
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
I pulled all three systems out of our rig. All Carrier. I have everything (except compressors) including boards, evaporators, condensers, and even the lines. They're just in my way but I'm in Oregon so shipping might be silly.
We've done so much, for so long, with so little, that we can now do the impossible, overnight, with nothing.
The United States Marines, America's 911 force -- 6531, 3521 '79-'99
Retired mech (auto/aviation), Extra Class HAM, NAUI/PADI OpenWater
HamSkoolie is offline   Reply With Quote
