Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-30-2021, 08:23 PM   #1
Can I replace factory AC w smaller unit?
So I plan on keeping my busí original AC but itís just so big and bulky that Iím wondering if I can have someone replace it with something smaller but still using the same wires and tubes as the factory AC.
I donít know much about HVAC and I havenít seen much discourse about this so Iím not sure if theres a really simple reason why more people havenít done this.
Any info would be helpful thanks!
handtowel is offline   Reply With Quote
Old 11-30-2021, 11:14 PM   #2
Chassis: TC2000 28ft
It's probably rifled air or carrier trans cool.
I believe in 2003 it was a $9000 option, so I bet a smaller evaporater would cost a ton from them. You may be able to find one at a scrapyard and reinstall, but even DIY, you'll spend money on guages, vaccum pump, $300 of r134a and various fittings needed for the hookup. I would advise that if it's working, just to leave it. If it's rifled, below are the options of evaporators that they have.
Bus Air Conditioning Evaporators - Rifled Air Conditioning
Old 12-01-2021, 08:20 AM   #3
you certainly can replace it.. my suggestion would be to install a bulkhead evaporator up-front in the front bulkhead. if you are insulating your bus well you may very well be able to delete the rear system altogether if your bus has 2 and the passengers plan to ride up front during road trips.
here is an example of one. don brown isnt likely the best place. shop around for a used one or better pricing but id expect to pay a grand or so for one.
https://donbrownbusparts.com/product...002-1001325385
these are typically sized very similar to a Carrier EM-1 or a Trans/ AIR 4-vent dual blower system.
not knowing what your current evaporator and condenser model numbers are makes it a bit tougher for me to help you out..
Old 12-01-2021, 08:24 AM   #4
the Most common systems are Carrier Transicold and Trans / AIR (factory OEM for bluebird)..
ive taken some Rifled-air and others out over the years.. ACC / ACT are showing up more nowadays under the brand ProAir LLC. If you want to build a complete custom system then ProAir offers all kinds of neat gear to do it.. I gutted my Driver Heater Box and built a custom Dashboard A/C system that also features dehumidified Defrost.. this doesnt cool the whole bus (I have more units).. but does make the driver area nice N cool away from engine heat!
Old 12-01-2021, 01:36 PM   #5
Has anyone converted from rubber to copper linesets and brazes/solder? The barb fittings seems to be a weak point.
Old 12-01-2021, 01:47 PM   #6
Nada. I use burgaflex fittings and never have leaks.. built my front system 5 and a half years ago and haven’t added Freon .. my rear system 2 years..
Copper and braze is too Boomer-Esque for me and I don’t like it in a vehicle with vibrations ..
