Old 10-03-2022, 04:55 PM   #1
Can you keep dash AC, but remove the large rear unit?
Hello, first time bus builder here. Just wondering if it is possible to remove the large rear AC unit. But, keep the dash AC working or are they usually linked together? I know most people's opinion is to keep the rear ac, but I have a short bus and would like the space if possible. So just exploring options.
Thanks for any tips in advance!
Shantimoves is offline   Reply With Quote
Old 10-03-2022, 06:11 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
your bus type will help answer that.
i did exactly that on my wifes 04 chevy shorty cutaway.
but i had several chevy versions to choose from as far as standard vans/tahoe/suburban.
Old 10-03-2022, 09:06 PM   #3
Sorry, should have included that. It's a 2009 Chevy Collins. You mentioning your wife has an 04 chevy sounds promising!
Old 10-04-2022, 01:36 PM   #4
Year: 86
Chassis: Ford B700
Engine: 8.2
yes 04 chevy collins.
got rid of the unit in the back and the underskirt condensor and bought a used van condensor from LKQ for like 50$ and the new proper lines from parts geek for around 50$ for both of them and did the install myself.
Old 10-05-2022, 01:04 AM   #5
OK, sweet. Thanks for pointing me in the right direction!
Old 10-05-2022, 12:11 PM   #6
Chassis: Ford E450
Engine: V10 Gas
Because you're new to the forum you may not have seen the extensive discussions regarding the pros and cons of removing the rear A/C unit.
Many folks in the forum suggest you carefully consider whether you want a rig that has no means to keep cool on the road (as you will if you removed the rear unit). Some folks don't care as they are chasing 70 degrees, so to speak. Others have come to regret removing the unit as they travel through the southwest in the summer.
A mini-split generally cannot be run while driving.
Old 10-08-2022, 10:05 PM   #7
Be Careful. If your bus has only one A/C compressor then they are fore sure hooked together.
On my school’s small buses the factory A/C condenser is is not used at all even though the dash evaporator is still used.
Mekanic is offline   Reply With Quote
Old 10-09-2022, 08:10 AM   #8
interesting that your busses would even have the factory condenser in front of the radiator.. the van chassis usually ship without them if a tie-in system is being installed..
Old 10-09-2022, 12:15 PM   #9
If you decide to get rid of it, I’d be interested in it!
ShanksToYou is offline   Reply With Quote
