Cadillackid you are right. I just mounted the whole chinaspacher pump mount over the volvo fuel pump mount stud. I had already mounted the chinaspacher pumps and the click click click drove me up the wall. And then there was the wife's concerns too. I already knew about the volvo pump mounts because some times the mounts would fall apart and people would solid mount them and it was quite noisy. With that in mind I just grabbed 2 mounts and remounted them in the same hole I had drilled earlier. I have also used them to mount radios in heavy equipment to stop harsh vibrations from damaging the radios. These things are pretty nice for other build projects too.
