We just got done spraying our bus this weekend. That stuff seems to stick to just about anything, so I don't see why kilmat would be an issue. May have to spray a light coating on it first so that the weight of the foam doesn't tear it away from the surface, then when cured, go back and add more.
If you haven't done the kilmat yet and plan to do spray foam, you may want to research that particular combination some more. Seems to me that foam over kilmat would have same effect as a little more foam with no kilmat, maybe saving you $$$.
BTW, with spray foam, we found that we got about half the yield that the kit stated (HandiFoam). And yes, we got everything up to temp. We actually had to buy more foam, to finish the job. It took four kits, two size 500 and two size 600 to do a full length bus. So beware, we likely would have saved a lot of $$$ and work if we had it professionally sprayed. YMMV
