Old 09-17-2023, 09:59 AM   #1
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
Dryer location 1995 International/Bluebird
1995/96 7 window conventional bus, with Trans/Air single rear Evaporator unit.
This uses two engine mounted compressors supplying two separate evaporators in one housing. One of the compressors locked up, and I have procured a new compressor, but for the life of me I cannot find the accumulator/filter/dryers on this bus. I have looked at the output of the two skirt mounted condensers, and the rear of the evaporator has a wire mesh air intake that you can see up into the back of the evaporator-- but I cannot see them there either. The AC hoses look "sort of " new-- with quick clip connectors.
Anyone have suggestions as to how to proceed? I hate to install the new compressor without replacing or installing a filer dryer.
PorchDog is offline   Reply With Quote
