I have the exact model you linked. 14000 BTU Whynter with the heating element. Have not tried the heater yet, but I have to say, the ac works surprisingly well. I was able to cool a 38 ft dog nose in East Texas to 68-70 during 95-plus degree days last summer. I made a panel that fits in the top section of a window with two properly sized holes and mounted the hose connections to it. Mostly I have thought of it as a temporary thing to use while building, but the nice thing is, it can easily be moved to different areas as needed or even removed when not needed. Or it could be semipermanently vented out the side wall and hidden in a cabinet type structure.
As I am currently downsizing to a 5 window van cutaway, I will probably go with a roof ac to save interior space.
Also, I have to mention two more things... it is extremely quiet, even on max setting. The other thing is that in our high humidity area, the condensation reservoir fills up fairly quickly (like a few hours) and must be emptied, or the unit cuts itself off. There is a place where an external drain could be attached so that water would not collect in the reservoir, but drain out the bottom of the bus (or be plumbed to gray tank??).
Overall, though I have been happy with the unit and would consider using permanently in a large bus. Notably, I am able to run on a 15 amp breaker and it has never thrown.
Hope that helps.
RUSTYMETALGIRL
