thank you thank you thank you
I have kept all these notes.... I made a point to keep in mind hose size and routing so has to keep bends to a minimum.
I will install air "guides" to direct air underneath. Keep as much heat from engine / transmission away from intake air for the condenser. I think I will also be able to duct "ram" air flow from outside the bus body to feed higher pressure air to condenser at the skirt. I feel very good about knowing how to direct air flow and aerodynamics.
I never thought about pulley speeds on the compressor.... I intend cruise rpm in 6th to be about 1900 rpm and if I drop to 5th at 65 mph engine speed would be 2500 rpm.... so I will work on some sort of circuit that can count crank rpm and shut out relays over 2600-2700 rpm. I do have the dodge crank speed sensor and can use that for ac circuit speed sensor.... now I have to go to some ciphering.
I found a place in Iowa.... from what you said, and looking at the SDS, I assume this is the supplier you are talking about...
I have the hoses that came with the EM1 system, IF these hoses are not the same as size as you used, how to did you alter the size at the evaporator? I have not yet check sizes of fittings screwed into the TXV..... Did you change the fittings?
thanks again for sharing your work and knowledge.
william
