Hi all, I happened upon a fellow in Virginia on Facebook that was giving away the factory AC system from his 05(?) Thomas bus. While it was a dognose bus, it had the same Cat C7 engine as my FE transit bus, so I said "I'll take it!". A friend of mine has picked up all the parts and I'll get them from him in June.
The plan at this point is to install probably just one compressor and one exchanger inside near the front. I have been told that the complete system is coming to me: two compressors, all the inside exchangers, and who knows what else. I'm sure it's not sealed up so I'll have to replace or blow out the lines somehow. I have not done a lot of research into AC systems at this point but I did flare my own mini split fittings so I guess I'm not a total n00b
. I'm not sure about the compressor bracket either, I'm hoping that's included but if not that may be the one "big expense" of this system other than refrigerant.
Any tips, reading material/references, or thoughts would be appreciated.
