Factory Evaporator Unit Cover Ideas
We are less than two weeks away from finishing our build and hitting the road. One of the last things that needs to be done is cover up our Carrier AC unit that is in the front of our bus. Somewhere along the way in our build and between moving and cleaning out junk from the garage we got rid of the plastic cover. I had planned to just cover the unit with wood and make is look like part of the cabinets. Now I’m having second thoughts about moisture forming inside the evaporator and having issues with wet wood. I’m thinking of ways to waterseal the wood before installing first. Maybe use cedar or cypress and spar urethane the crap out of it. How much water accumulates inside the plastic cover? We have a drain hooked up that goes out the bottom of the bus. Does the drain catch all of the water typically? Thanks for any and all input!
