Old 07-23-2017, 09:49 AM   #1
Factory wall mounted ac
Just bought a bus from TX that has Factory ac units one in the rear one on the drivers side half way down should i try to keep them or scrap them ???
karl269 is offline   Reply With Quote
Old 07-23-2017, 10:10 AM   #2
Do you want AC when you are going down the road?
If so, can you accommodate the units in your layout/design?
If you answered yes to both then keep them.
Old 07-23-2017, 10:51 AM   #3
we will have our dog and cats with us ac is critical when going down the road
Old 07-23-2017, 11:38 AM   #4
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Then keep them. They won't help while parked, unless you run the motor... But they are good for when moving down the road or in an emergency when your parked.
Old 07-23-2017, 11:44 AM   #5
I wouldnt have it any other way... it takes a LOT of A/C to overcome the engine heat, road heat, etc... so even if you put in rooftops / minisplit etc for when parked it isnt going to do much for keeping you cool on the road..
I added dual units to one of my busses and re-vamped the unit in my other bus so i can be sweat-less on trips in the summer south
