Old 09-06-2021, 11:30 PM   #1
Year: 1967
Coachwork: Gillig
Chassis: Chevrolet B-Series
Engine: 366 V-8
Floor-vented gas heater
Does anyone know of a floor-vented propane heater? I recently purchased a ProTemp water heater that exhausts through the floor and is a really clean install. Was wondering if there is a similar setup out there for a space heater? I'm trying to minimize the holes I'm putting in the walls and roof.
paddywagon is offline   Reply With Quote
Old 09-06-2021, 11:39 PM   #2
Chassis: Front Engine
Not propane but all of the air diesel heaters do the same thing. Webasto, espar and the Chinese clones.
rffffffff is offline   Reply With Quote
Old 09-07-2021, 12:13 AM   #3
Propex, HS221 is a good one.
Best to mount it outside and vent the heated air into the interior though.
Old 09-08-2021, 10:09 AM   #4
Year: 1967
Coachwork: Gillig
Engine: 366 V-8
Just looked it up and it's exactly what I'm looking for. Thanks!
Old 09-08-2021, 12:01 PM   #5
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
Why do propane heat at all? The moisture those things generate will trash a bus interior in short order if you don't ventilate properly.
The new diesel air heaters are so easy and reliable it blows my mind why people still waste time and money on those propane furnaces.
Old 09-08-2021, 12:24 PM   #6
Over a pint of moisture for every lb of propane burned.
Old 09-08-2021, 12:41 PM   #7
The Propex unit produces ZERO moisture inside.
All the burn output is vented to the outdoors.
Only fresh air from outside is heated.
Just like the diesel and gasoline fueled parking heaters.
Old 09-08-2021, 01:05 PM   #8
WIbluebird's Avatar
Rated Cap: 75
But then you're dealing with constantly having to top off propane tanks to stay warm.
With a diesel heater plumbed into the bus tank it's as easy as keeping the tank full.
Less work the better I say.
Old 09-08-2021, 01:09 PM   #9
Most rvs have decent propane storage and it’s likely a lot cheaper to run propane than diesel I would guess. I kinda agree with the single fuel idea but propane stoves are fairly ubiquitous too. Either way, makes sense for some and not for others.
Old 09-08-2021, 01:44 PM   #10
Get a bigger propane tank. I think I wil have no issues with a 29.3g tank.
Old 09-08-2021, 01:55 PM   #11
The most satisfying times I’ve had with my bus have been when I was cutting holes in it
Old 09-08-2021, 02:05 PM   #12
Bert06840's Avatar
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 26,000 lbs
Don't get one like mine then, many of the parts are stainless steel and cutting or drilling it is a royal PITA.
It's exactly the opposite for me. Things I hate about our bus are:
1. the insurance nightmare
2. thick, hard, oversized, inaccessible material and fasteners. Removing/cutting/drilling anything is such a suffering. Why two quarter inch thick, 3" wide stainless steel brackets to hold up a single seat? Why?
Bert06840 is offline   Reply With Quote
Old 09-08-2021, 02:14 PM   #13
Many feel kids' lives are worth over engineering
Old 09-08-2021, 11:30 PM   #14
Year: 1967
Coachwork: Gillig
Engine: 366 V-8
I have good reason for going propane. My bus runs on petrol, not diesel, so I don't have diesel on board to begin with. My stove and water heater are propane, so that made the most sense.
My water heater and soon-to-be furnace are both externally vented which means they use outside air for combustion and exhaust outside. This prevents oxygen depletion and moisture buildup (as well as toxic emissions) inside the bus.
I have a strong opinion against putting holes in my bus, or at least the walls and roof. Any opening creates the potential for a leak and I love the clean, uninterrupted lines of my bus.
Old 09-09-2021, 12:48 AM   #15
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Look into a "cheap chinese" plasma torch. There are a couple of youtube videos out with $200 plasma torches that work great. I bought a better brand from a local welding shop but LOVE mine.
HamSkoolie is offline   Reply With Quote
Old 09-09-2021, 12:49 AM   #16
HamSkoolie's Avatar
They need to meet some of today's hellio......ummm....er kids
Old 09-09-2021, 06:30 AM   #17
another advantage to propane is odor outside.. if you are in a campground where there's lots of other people, diesel heaters do emit diesel fumes when running.. propane exhaust is much less odor for those around..
I love my diesel heaters and for what I use my bus for its the perfect solution. . propane hjeaters with ehat exchangers leave zero moisture inside.. if you get good ones that are condensing then you end up with 95% or so efficiency as well.
Old 09-09-2021, 12:44 PM   #18
Yes that Propex unit is both very fuel efficient on the LPG, and not too thirsty electrically.
Mounting outside helps make it quiet within the living space
Old 09-09-2021, 12:50 PM   #19
Good point. Maybe I keep my little catalytic heater installed for times like that
Old 09-12-2021, 09:02 PM   #20
Year: 2005
Chassis: FC
Engine: Cat C-7
I did both the diesel air heater and a propane Catyletic. Offers flexible heat options. I also kept the original bus hot water heaters for underway
ChuckRatto is offline   Reply With Quote
