Originally Posted by BusDreamerRick
Hello we are looking to do a similar floor in our bus and I am wondering how this went? If you could share some pictures or videos if you have them that would be awesome! I am also trying to figure out what the oak dowel system looks like. Thank you!
I don't really have the technique shown in just one place (my build thread is pretty long), but this is where I started on the dowel thing in the back of my bus:
https://www.skoolie.net/forums/f11/r...tml#post391014
And this is where I started laying the XPS insulation:
https://www.skoolie.net/forums/f11/r...tml#post394886
In words, I basically weld a bunch of wood screws point-up on the floor. I then cut a piece of XPS foam board and press it into place over the screws, which leave indentations in the board. I then pull the board back up and use a 1.25" hole saw with the pilot bit placed into each indentation to drill holes. I then place the XPS back down on the floor and spin 2" pieces of 1.25" diameter oak dowel (with a pre-drilled hole with counterbore in the middle to take the screw) down to the floor through each hole, using a special tool I welded up that is hammered onto the end of each dowel and turned with a ratchet wrench.
I used oak rather than pine because in some places (due to the layout of the plywood on top) I had to run 2 to 4 screws into the dowel instead of just one, and pine dowel is likely to split whereas oak holds together.
