06-20-2019, 05:48 PM
#21
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Zandria06
50ft 16/3 SJTW Orange Cord
it's likely you're going to fry something - something is getting very hot - if it isn't melting, I'd be surprised
06-20-2019, 05:50 PM
#22
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
What if I got a rv cord 30amp that’s 10g with the adapter?
that is about as good as your going to get with the wire - the Gen might still be on the small size
06-20-2019, 05:55 PM
#23
Originally Posted by o1marc
That cord is way too long, keep it as short as you can manage with, 25ft is plenty.
06-20-2019, 05:59 PM
#24
I got a 30amp rv extension cord 10g wire with the 15amp adapters in a 30ft length I will order another generator tonight recommendations are appreciated
06-20-2019, 06:27 PM
#25
That did the same thing as well. So new generator it is uhh
06-26-2019, 07:27 PM
#26
Coachwork: Ward
Engine: 5.9L DTA360
Rated Cap: 65 passenger
It's the surge. Air conditioners have huge inrush demand. Unfortunately I'd urge you to find something more like a 5kw unit, keep in mind most combustion engines run most efficiently at 80% load, and I've been told to size a generator 5x your average demand. A 5kw unit will run my whole house, but barely. It can run a large window unit fine, water heater alone, or everything else.
My GE 6,000-BTU portable air
conditioner(1010w) keeps tripping the Circuit On my Sportsman Gasoline 2,000 Surge Watt Portable Generator. It does run for about 4 minutes then kicks off the circuit. Help!! I’m in Texas it’s Hot ��
06-26-2019, 09:34 PM
#27
The price of the 10/3 almost gave me a heart attack
06-27-2019, 05:37 PM
#28
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
I’m where the tornado hit yesterday (Greenville) I don’t expect it to be below 80 but the bus isn’t insulated except for the floors. All my windows are covered and have no problem upping my generator size. I am just wondering if something is wrong with the ac unit I can put it on fan and it will stay on no problems just put it on low and eco and it cuts off
If you can, plug it into a regular house circuit and see if the prob goes away.
06-27-2019, 08:55 PM
#29
Engine: Cummins 5.9L 24v
Rated Cap: 82
Would a soft start (capacitor) not help with this problem?
06-27-2019, 09:04 PM
#30
OK so how hot is it in the bus? you say it runs for like 4 minutes before kicking the breaker... the surge current is instant.. it would trip the breaker the minute the unit came on .. but very hot interior and a portable unit that already has undersize condensor... it runs the head pressure off the scale.. which makes the compressor pull huge amounts of current.. sometimes enough to trip the internal thermal on the compressor.. other times just so much current that it kills off the breaker in the generator..
if you plug a 1500 watt space heater into your generator without the extension cord does it do the same thing?is this 2000 watt generator, 2000 watts off of one 110 volt leg? or is it expected to see a total of 2000 watts using a 220 volt load which pulls off of 2 legs.. ?
06-28-2019, 09:00 AM
#31
Ok everyone after getting a 4,000w generator in and the air conditioner did the same thing I took it back and got a window unit and removed the 2 small screws at the bottom of the window and it fit so now my air conditioner works with no problem go to Instagram search skooliemom to see video & picture
06-28-2019, 09:02 AM
#32
Chassis: IH 3800, 8 window
Occam's Razor strikes again!
Glad you got resolution. And relief..!
06-28-2019, 09:43 AM
#33
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
Soft start!!
YOU NEED A SOFT START, THAT WILL SOLVE ALL YOUR AC PROBLEMS
06-28-2019, 10:47 AM
#34
Right me too
06-28-2019, 11:04 AM
#35
You're way more likely to get Instagram hits if you paste the link, instead of sending folx on an Easter Egg hunt!
Just sayin'...
06-28-2019, 11:45 AM
#36
I just needed a different air conditioner the one I got was broken it was plugged into the house and had the same problem
