Old 08-28-2020, 08:19 AM   #1
Year: 1994
Chassis: TC 2000
Engine: Cummins Turbo 5.9
help installing compressor - las vegas
Hello everyone - I am looking for someone to install a compressor in a bus I purchased that is stored in Las Vegas. the bus is a 1994 Bluebird TC 2000. Im in Indiana and the previous owner says that is all that it needs for the AC to work in the bus. Thanks in advance
slummieschap is offline   Reply With Quote
Old 08-28-2020, 01:58 PM   #2
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
i would not believe a previous owner unless he showed a estimate from a ac man that stated that. you are buying it "as is" so once he got your cash .........
mmoore6856 is offline   Reply With Quote
Old 08-28-2020, 06:37 PM   #3
im in ohio.. is the A/C compressor on the bus or was it removed? how did they determine it is bad? I recently fixed a dual A/C system where the compressor wires on both of that persons A/C's had broken off in the harness a foot or so back due to poor factory splices..
also unusual for a Bluebird TC to only have 1 compressor and not 2, esp on a 5.9..
Old 08-28-2020, 07:15 PM   #4
I should also add that if the compressor broke mechanically.. ie locked up and the system oil isnt still perfectly clear then the system will nbeed a complete flush.. and any time you replace a compressor it will need a new receiver / drier , and then a complete refrigerant charge (you never re-use freon from a compressor failure and obviously the labor involved to do the work.. sometimes working on a front engine TC can be a royal pain..
Old 08-29-2020, 08:28 AM   #5
Year: 1994
Chassis: TC 2000
hi mmmoore - i knew the ac wasn't working when I bought it. It was the previous sellers assumption that it was the compressor.
Old 08-29-2020, 08:32 AM   #6
Year: 1994
Chassis: TC 2000
Hello cadillac kid - not sure about any answers to your questions. As i stated to mmmore I knew the ac didn't work when I bought the bus and seller assumed it was the compressor. Didn't realize that there maybe 2 compressors though. Not happy to hear that a front engine TC is a pain to work on. Thanks for your input though.
Old 08-29-2020, 10:41 AM   #7
It’s worth doing a full analysis on the system.. often on that engine and bus the compressors are down low on the engine at the front..
A compressor that fails to spin can be anything from a bad wire to low freon to bad compressor.. (low freon would mean some sort of leak).. your bus may only have 1 system but most have 2 except a short bus (6 or 7 window ) will often have 1. And yet others have one big monster compressor but those are not as common on school busses
Old 08-31-2020, 02:53 PM   #8
Year: 1994
Chassis: TC 2000
hello cadillac kid - you've helped me immensely. Thanks.
Old 08-31-2020, 04:12 PM   #9
Year: 1994
Chassis: TC 2000
Hi Cadillackid - what an all expenses paid trip to Las Vegas?
