Starting to put my Webasto together to do a bench test
I am trying to figure out how to wire the DP30 fuel pump. This is sold without the plug wired to allow you to trim to length and then finish the terminations. The problem is I am not sure how to wire it (which wire connects to which terminal on the pump). I did a bit of googling, but the best answer I could come up with is a pigtail that shows where the blue wire goes (this is the signal wire from the Webasto). Would it matter if I hooked it up backwards? (i.e. would it damage the pump?)
