hydronic heated floor x45 diesel
hey all and thank you in advance for your help!
i have a 06 bluebird cat7 and we have an external x45 proheat diesel heater. were using it to run a hydronic system. one loop for heated floor, one for heat transfer for hot water and one radiator. my questions
Is there a way to lower temperature in diesel heater, right now its set for shot off 185Fdegrees back on 150F. way to hot for my pex flooring.
if temperature is left alone can it be regulated with a globe valve which controls water flow?
also is a xtra flow tank/expansion tank needed? if so how big?
thanks again andy
