Old 02-17-2020, 04:59 PM   #1
Insulation on ceiling
Is the being insulation in newer buses (mine’s a 2004 short bus) better than in older large school buses? Has anyone just left it in and left the original metal roof undisturbed?
I was thinking of doing that or taking it out and putting XPS in the ceiling
BusZen2003 is offline   Reply With Quote
Old 02-17-2020, 05:11 PM   #2
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
I like the metal roofs. I wasn't going to take mine down when I bought a bus. But the bus I bought had perforated ceiling that I didn't like. And speakers in each panel. So I took mine down and decided to insulate with XPS.
I guess the XPS will be better insulation. Plenty of people leave theirs in and don't mind. More people take everything out and run spray foam. My bus is 2003 and the fiberglass was in good shape when I took it out. The walls were nasty though. I imagine yours isn't too bad unless you have a leak or something. But are you going to be in hot or cold temps? Leaving all your windows in place? Raising the roof?
All those answers will lead to a better decision that works for you.
JDSquared is offline   Reply With Quote
Old 02-17-2020, 06:50 PM   #3
Would like to be in both hot and cold temps. I don’t want temp to dictate where I can go. No roof raise. Keeping all windows and emergency hatch.
Old 02-17-2020, 07:15 PM   #4
jofred99's Avatar
Chassis: TC2000-8 Window
Engine: Cumm ISB/Allison 2000
I wanted to leave my metal roof intact, but after taking my wiring guards down, I found a few roof leaks. Very glad that I removed all the ceiling metal. It will also give better access for when I mount the PV panels to the roof.
jofred99 is offline   Reply With Quote
Old 02-17-2020, 09:31 PM   #5
Ronnie's Avatar
Engine: 345 international V-8
I left my ceiling intact, and have seen a number of buses with them still intact. Windows are a big loss of heat. If you are going to push the extremes you will want all the insulation you can get. Read the "Arctic family bus"
Old 02-17-2020, 10:21 PM   #6
I have heard "The arctic Family Bus" mentioned a few ties now. I suppose it is time to read ... alot.
Old 02-17-2020, 10:29 PM   #7
It really put my fear of driving into New Jersey in the rain in perspective.
