Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 06-28-2021, 02:18 PM   #1
Wink ISO Carrier EM-1 Wiring Diagram / Schematic
howdy! we've got a 2004 e450 starcraft allstar shuttle bus with the carrier EM-1 AC in the back. a wire or two was disconnected from the RCT circuit board installed by starcraft and i cant seem to get the thing to turn on (cooler). I have found 2 separate manuals, of which gives very very very small amount of voltage diagnosis but its not enough! I am looking for the wiring diagram for the Carrier-EM1 or any similar carrier AC system with the 0 1 2 3 4 speed setting : ) if you also have experience working with these and want to help me out that would be nice too : )
gollum is offline   Reply With Quote
Old 06-28-2021, 02:49 PM   #2
found it online!
Old 06-28-2021, 04:44 PM   #3
its possible to wire these so that the inside fans wont turn on unless the pressure switch is good.. many of these are Tie-in to the dashboard A/C on a Van-bus.. so the dash A/C has to be on and working before the rear unit will turn on and blow cold.. if under the hood you only have 1 compressor then this is likely the case
Old 10-08-2021, 04:29 PM   #4
Resistor & One Diode valves
I need a big help. Can anyone have the values of these two items on figure 5-3 Resistor s and one way diode on the condenser blowers. I do appreciate for your help. Thank you.
alex808 is offline   Reply With Quote
Old 10-08-2021, 04:35 PM   #5
Resistor & Diode Values
Can anyone tell me the values of these items on figure 5-3.
Before the condenser blowers. Thank you.
File Type: jpeg 49ECF792-0620-4ABD-A512-D91DC9C937B9.jpeg (212.7 KB, 5 views)
allstar, carrier, diagram, em-1, starcraft
