Old 07-26-2021, 04:29 PM   #1
The Game is Afoot's Avatar
Chassis: 39' CS RE
Engine: ISC 8.3/Alisson B400R
KEEP old insulation?
Hey all -
So. Our bus has spray foam insulation. 1"
Removing it is proving to be a BEAST. 😂
Any tips or tricks?
We have also considered keeping it except for the parts that are really black.
Original intention was to use wool for eco-friendliness but the beast of work of scraping this stuff off has us reconsidering.
What would you do?
Pics attached.
The Game is Afoot is offline   Reply With Quote
Old 07-26-2021, 04:33 PM   #2
Leave it, replace only what needs replacing. Most of us would use this type insulation if not for the expense and mess.
Old 07-26-2021, 05:11 PM   #3
I’d be pretty happy to find that
Old 07-26-2021, 07:08 PM   #4
The only downside to this particular stuff is that it's not completely flush with the insides of the ribs, so it's OK but not providing quite as much insulating value as you could get between the roof panels and the headliner (whatever you use for that). If this were my bus, I would add furring strips (either side-to-side on each rib or front-to-back across the ribs) and use spray foam to bring the insulation out flush with the insides of the furring strips (keeping what's there already in place).
Old 07-26-2021, 08:18 PM   #5
Engine: DT466e 215hp Allison 2500
Is the black is it mildew? Test this out in a small area, try a little wash down with a towel soaking with water and 10% bleach maybe a little Dawn. If it's mildew it may disappear quick and easy.
Timeline is offline   Reply With Quote
Old 07-26-2021, 09:18 PM   #6
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Looks like soot from exaust. Particles travel through the wiremold from the RE where the harness passes into the engine bay.
Is it more prevelant where the harness trunk-line branches out? We had soot. Leaky buses.
I'd keep the insulation. Maybe add more foam, if you're able. Closed cell will encapsulate what's there. If it were mold (unlikely), just being present, while it's being pulverized, seems less healthy than the alternative, imho.
Old 07-26-2021, 11:17 PM   #7
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Like Danjo said...this would make me happy to see! It may not be enough insulation for your needs, but it's a good substrate for any additional insulation you want to add. Definitely don't rip it out.
