08-05-2024, 02:04 PM
Lost R410a during install. What's next?
I just installed a Pioneer 12,000 BTU mini-split in my bus this last weekend. Unfortunately, when I released the refrigerant into the system I found a substantial leak. I fixed the leak and got the system working but I'm sure it doesn't have enough refrigerant in it. I'm only measuring about 30 psi and I know that the PSI should be closer to 150.
This morning I thought it might be a good idea to get an HVAC tech out to refill the system with R410a. Every single place I called refused to work on it because it was installed in a motor home (I told them motor home rather than school bus just in case they are prejudiced). Every store that carries R410a wanted me to have an HVAC license and an EPA certification before selling to me.
This created a true Catch-22.
I found a place on-line to sell me the refrigerant and I guess I'll just top up the system myself over the weekend. Has anybody else run into this problem? What have you done to deal with it?
08-05-2024, 02:17 PM
thats distributors.. technically you dont need an EPA cert to buy R410A but many sellers have a policy just to require it for all..(andf technicaslly you need a license to actually use it.)
the only correct way to install R410A in a minisplit is to recover the rest of the charge and then recharge in by weight.. some of the nicer ones like mitsubishi and fujitsu have a testing cycle mode where you can charge by superheat but with a heat pump that has an accumulator thats not a correct way to charge one.. I only ever charge them by weight
I dont know of any home-style minisplit that has been approved by its manufacturer for use in a mobile evironment.. (though many many people use them and they work fine).. as such companies wont touch a DIY install in a motorhome as they dont want the hassle if something doesnt work right.. (in their mind they are thinking a botched install that will end up with come-backs and not much profit)..
best bet is if your community has a local page or group on social media you can reach out there in hopes of finding someone who is independent and can pump it up for you. if you were in central ohio I would do it.
08-05-2024, 03:02 PM
Thanks, I do understand. It seems like every "professional", no matter the field, has a prejudice against anyone that attempts to do their job. Guess what? Some people are actually competent. I have a good deal of animosity towards folks with this attitude. I've been building things my entire life and I"m almost 70. During the pandemic I built a boat. On the river folks say it's the most beautiful boat they've seen on the river. I do good work. I know how to learn things. The one benefit of having a Ph.D is that you figure out how to learn things on your own.
I wish the install went perfectly. I was very frustrated that I couldn't do a positive pressure test first. The vacuum level test worked fine but it didn't hold when the pressure was increased. One of the gas connections inside the bus just started spewing gas and I lost much of the refrigerant. I actually completely replaced that line because I though the problem was a kink in the line (it wasn't). Once everything was assembled again the system worked but it only has 30psi and it should have closer to 150psi.
It seems like "professionals" want to punish anyone who dares too DIY. Sometimes you run into problems that you can't solve easily. I tried to install front shocks into my 4runner and I just don't weigh enough to compress the springs. I started the job, realized that I didn't weigh enough to compress the springs. It took me days to find a mechanic who would finish the work because "I started it myself". I had the system completely back to it's original state before I even started calling around but because "I had started it myself" most folks didn't want to touch it. I finally found a guy that would install them but the attitude I ran into really soured me on having "professionals" do the work.
I'll finish off the installation when the refrigerant arrives but I'll never bother trying to "get help" from anyone in that industry.
Sorry, I'm a little bitter about this. Sometimes it would be nice to just get a little help.
08-05-2024, 03:39 PM
100%!!!
I was an HVAC tech turned engineer for years and I try wherever i can to help people complete their own HVAC projects because I know 99% of them are straight forward.. like I say if you were near me id be glad to fix up your unit and show you what I am doing while i do it..
I only gave the reasons given to me by the guys I know still in the business.. many of the guys will help on the side but some of their companies disallow it..
the flare fittings on minisplits are some of the most failure prone things out there.. many of the flares on the liens from the china factories are not deep enough or are flared crooked so a connection will feel tight when its not..
I use Nylog blue on all my flare connections.. and I also make new flares too.. flaring tools are easy to get (HVAC flares are different than brake flares)..
nylog blue can be ordered from amazon and its a solution you put on the flare which helps to seal it.. i have great luck using it..
08-06-2024, 05:16 PM
Chassis: AARE
Engine: 3116 Cat 250hp
I was in the same situation 10 years ago. Made a mistake, lost freon, fixed mistake, no one would recharge. Well, one would but wanted an arm and a leg and my second born. I might have given him my first born.
I don't have a PhD but, you don't need one to do this.
I bought the correct gauges, adapters and vacuum pump from HF. Bought the R410a online. You will need an accurate scale to do it right. Freon scales are expensive. Postal scales are cheap.
I haven't had any problems since I fixed it about 10 years ago.
I don't know where you are but, judging by your profile picture you must be near water. I'm not so, probably too far for me to help.
08-06-2024, 05:35 PM
postal scale works good enough.. I have a real HVAC scale but a postal scale (the 70 lb version) works just fine..
