05-18-2023, 06:23 AM
Coachwork: Bluebird All American Re
Mini split outside condenser placement
Has anybody with a rear engine bus mounted a minisplit outside unit inside the engine compartment? Looks to be plenty of room. I am putting the inside unit on the back wall of the bus and this would make installation a lot easier, otherwise it's a 30ft run towards the front of the bus to mount it under. Concerned about minisplit efficiency and operation as well as causing temperature issues with the engine. Any experience or thoughts?
05-18-2023, 09:38 AM
Chassis: Ford E450
Engine: V10 Gas
I have not, but the principle that condensor is operating under is temperature differential. If the engine compartment air temperature goes above 100 degrees, exchange efficiency drops (and the unit has to work harder).
And where does all that hot air from the condensor go? Circulation would be the other big concern.
05-18-2023, 11:17 AM
Gotcha! Under the side skirt between storage area and front axle it is then!
05-18-2023, 05:50 PM
Chassis: Ford E450
Engine: V10 Gas
That's a common location. Ground clearance is a thing, but many folks put them under the bus and report no issues with road dust/dirt, etc.
05-25-2023, 03:33 AM
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
mounting the condensers in the rear engine compartment would be like mounting them behind the radiator on a front engine vehicle, no cooling for the condenser.
My factory (Thomas Built) ac condensers are under the buses on the sides, with fans (in front of the rear axle). No clearance problems and are directly under the evaporators, so both evap and condenser have long lines to the compressor. You could just have both lines short if you mount the split components in similar locations. Seems you could have a bit more flexibility in mounting the evap than the factory systems. I think that the evap bulk and location, directly opposite each other and in the center of the bus is a big reason why so many people delete the factory ac.
05-25-2023, 07:09 AM
I see a lot of them mounted under the bus.. some people cut holes in the skirt of the bus so the fan has a path to blow the hot (or cold) air out.. a couple people I now put a 1/4 spaced screen (not a window screen.. the holes are 1/4 inch) over the back of the unit to keep large rocks from hitting the rear coils where theres usually not much of a grill.. I dont k now if its necessary..
a lot of factory bus A/C systems had the coils mounted under the bus (not always skirt). and they seem to last.. the biggest issues is really road salt destroys the aluminum fins and eventually the copper coils on the factory systems.. I ordered a new condensor just this week for a guy that wants his factory bus A/C to work again on a 2011 bus that lives here in ohio.. and the failure was the condenser is just ate up from the road salt..
I think most people in skoolies tend to stay away from salt for the most part so you should be good... at least I hope when its salt season you are travelling your bus to warmer nicer places...
05-26-2023, 01:23 AM
Rated Cap: me + 1
You seem to be quite knowledgeable about bus a/c systems. Do you work on them as a side hustle?
05-26-2023, 08:58 AM
ive been doing A/C in general since the 80's, I did HVAC and advanced commercial HVAC controls as a career in the 90s.. before I saw the light and found I could make real $$ doing networks, code, telecom, and servers..
heck I remember fixing the A/C as a teen in our church busses.. no one wanted to try.. I had a stack of library books and learned it..
nowadays i do more helping people with re-purposing bus A/C gear that skoolies seem to want to get rid of.. ive put a lot of systems back into use again..
theres also quite a few small guy school bus contractors that one anywhere from 1-5 busses they service districts with.. take a 2011 bus to thermoking and they will charge you many hundreds just to look at it and then several grand to replace a condensor.. the same part I can order new for a grand.. and the mechanically adept driver can help install it.. Im also a tool geek so ive got the leak detectors and high perf vacuum pump, tanks, recovery unit, gauges, the EPA certs to get the refrigerant..
he slides me a couple hundred plus materials costs.. he is good friends with the owner of one of my fav coffee shops. so magically my espresso shots ring up as '0'...
while my career is fun and I enjoy it.. A/C is really fun to me.. I love building it, programming it, designing it.. ironically i really dont like when people over-use it.. I hard;ly turn it on in my house till its sleepy time..
now I do run it in my busses.. all the time... even my old 1978 SUperior I added a driver unit on steroids...
05-26-2023, 01:56 PM
Rated Cap: me + 1
thanks for the answer. Which do you spend more time in ...your house or the buses?
also, do you have any adsorption system experience or refrigeration experience?
05-26-2023, 03:11 PM
its a toss up sometimes whether I spend more time cruising my busses around or at the house.. lately at the house because work is wildly busy...
very little absorption system experience.. exposed to it but never got deep into it.. natural gas Home A/C systems were on their way out when I got into the business.. one factory we took care of had an ammonia system for their flash freeze but we only handled their trane chiller and space A/C...
refrigeration only in terms of grocery store walk in chiller / freezer mainly.. of course the usual unit beer coolers in bars / restaraunts.. (back then people could smoke in bars / restaraunts and it was always dirty coils)
