Originally Posted by shaymcquaid
I’ve mounted 2 under my bus.
The rear one is sorta’ in the engine compartment. I’m also gonna’ mount the generator in there.😎
They work great.
this install is damn near perfect.. the rear one isnt in the engine compartment using the side vent like the OP was mentioning doing.. your engine vents are clear.. the unit is down low and ahead of the engine.. that unit if any probvlem existed right after engine shutdown could easily be shrouded. but im guessing it has no issues because it is ahead and below.. not directly beside the engine compartment..
your fan is directly against the side of the bus so air recirculation isnt going to be an issue..
yeah this is a great install and it looks good too.. it doesnt look much different than ther side condensers for standard bus road A/C, or an RV generator..
KUDOS!!
