Somehow I ended up with a bus pretty different than what I thought I wanted in several ways, but most of them are hardly anything to complain about. For instance, one popped up in my search with THREE roof AC units, and a 10kW generator to run them. It also has no windows at all on the left side, two small RV-type windows on the right side, and one small window on the back. And it already has about 1.5" of spray insulation in the roof and sides, and a couple of inches of foam sprayed onto the floor from the underside with 3/4" plywood flooring on top of the metal. The price was acceptable, the timing was right, and AC and generators and spray foam were things I'd planned on eventually probably adding anyway. Long story short, I bought the bus in Colorado, drove my motorcycle out and picked it up, drove to Florida where I registered/titled, etc, and then drove to Maine where I thought I'd be doing the conversion. Along the way, I decided the giant generator was just way too big - it hangs down super low, it uses my precious fuel reserves, it's loud (compared to my dad's EU1000 which I know is an unfair comparison). I also decided I really dislike the 3 roof AC units. For one thing, my bus is a high roof (something like 6'8" standing height aft of the cab and about 6'1" from the driver's seat forward), and I've already crashed my AC units into things I wanted to drive under a few times. I also just think those big white warts on my roof are ugly (as a guy driving around in a skoolie I can't believe I'm even saying that). Despite my aversion to air conditioners and to big generators, I recognize that buses can get pretty hot and there are practical considerations here. So here is my tentative plan - somebody give me some real-world relevant feedback please.
I did my drive from CO to FL over two weeks between July and August. CO on the motorcycle was brutally hot and I expected my time on the bus to be a sufferfest because I wasn't running the generator yet, but to my surprise I was actually quite comfortable with the exception of about 2 days in GA and FL with temps and humidity in mid 90s. The only time that was really unbearable was a couple hours in GA where I sat in traffic on a 2-lane road without moving with the sun beating in through the windshield directly onto me. I found out then that the dash mounted fan didn't work, although blissfully the Red Dot ran with the engine on. I succumbed to my weakness and sat there with the engine running just to power the AC for about 90 minutes.
It got me thinking, maybe I don't even need AC at all. I'm kind of thinking that 95deg and 95% humidity is probably the worst I'll realistically see, and if it's manageable in any better conditions then I should plan for the expected typical more than the least-common fringe cases. Under my expected normal circumstances if the bus gets too hot I can run a fan or just get out of the bus, or just drive the bus somewhere cooler. In the uncommon situation where I "need" to be in the bus and it's super hot, the Red Dot is there in a pinch, although its location is not ideal for anything but driving.
I think I'm going to permanently ditch the two "conventional RV" roof ac units altogether, and also eliminate or severely reduce the size of my generator. I will retain my third roof AC unit, which is a lower profile 12V Red Dot unit of the type you often see on tractor trailer cabs and sometimes on the cab of small box trucks. This one is directly over the cab, which is about 8" lower than the rest of the roofline and visually sort of maintains the roof profile when you look at the bus in...profile. I have a deck hatch off a boat, and two Fantastic Fans for roof ventilation. I haven't finalized my electrical plans yet but I'm assuming that in addition to running AC with the engine on, I will be able to run my 12V, 47A roof AC for short periods (3-5 hours max) off a 300+Ah lithium battery bank (not yet purchased), maybe supplemented by a 2000W generator simultaneously charging the battery bank. I know this is not the ideal AC setup, but keep in mind that I'm thinking this is just a contingency for uncommon fringe situations. I also intend to add more insulation than what I already have. I'm sure there is a point of diminishing returns but I have something like 5 inches to play with for insulation between floor and ceiling, on top of the ~1.5" minimum that's already there. I'll add a couple windows but with only a couple windows to deal with I can afford higher quality with some R-value there, at least better than a normal school bus window would be.
Ok, I think I've laid out my ideas well enough. What do you all think? Is it dumb to think I will be able to just avoid the heat if it gets too much? Is several inches of insulation alone not going to keep a bus cool in the heat? Is my combination of insulation and fringe AC capability not going to do what I hope? Is the forward-mounted AC going to be useless for the rear end of the bus? Is the plan ok but a 20-year-old Red Dot too unreliable? Is it nuts to think any normal future travel partner will be comfortable in these conditions? Please give my plan some constructive critique before I commit.
