Old 06-30-2020, 11:19 AM   #1
need help finding a t-connection for A/C
I have a 2002 Corbeil mini bus GMC/ Chevy G31 with a rear A/C unit, I am have problem finding a t-connector that connects the front and rear A/C lines. I have sent pics of the connector that has been messed with to help. Any help will be appreciated.
Thanks
Frank
fcott1 is offline   Reply With Quote
Old 06-30-2020, 12:02 PM   #2
DawgBs's Avatar
Year: 1982
Coachwork: Ford
Chassis: E-350; 4x4 Minibus
Engine: 351c.i.
Without knowing your thread sizes/designations, you're probably going to have a hard time finding that exact tee. However, you can easily use other thread fittings/adapters and something like the included link to make it work.
https://www.hydraulicsdirect.com/Pro...RoCnJIQAvD_BwE
-Travis & the DawgBs
<<1982 E-350 cutaway, Collins Bantam ext. body, Maximum 4x4 F-350 drivetrain conversion>>
DawgBs is offline   Reply With Quote
Old 06-30-2020, 12:03 PM   #3
DawgBs's Avatar
Year: 1982
Coachwork: Ford
Engine: 351c.i.
If you can measure the threads (diameter/pitch/taper or no) of the lines and on the connector, you should be able to locate a matching connection.
Old 06-30-2020, 03:08 PM   #4
is that T fitting in the suction or liquid line?
Carrier transicold isnt manufactured anymore but if this T is on the back of the accumulator (the silver canister)? trying to figure out where the part is supposed to go and whats broken..
this #12 part in my MCC book (MCC makes a lot of carrier replacement parts).. looks similar but you should measure the threads to help us out..
Old 06-30-2020, 03:19 PM   #5
found some other sizes that same T..
on *AVERAGE* most bus A/C uses
#10 size from compressor into condensor
#8 size from condensor to evaporators (there would be a T someplace after the condensor )
#12 size from evaporator to accumulator (or back to compressor). there would be a T in this segment..
Old 07-01-2020, 03:50 PM   #6
I think this is the part . Where can I find one?
