Old 03-27-2017, 04:58 PM   #1
theradiumdial's Avatar
Year: 1985
Engine: 9.0L v8 IHC
Rated Cap: 54 passenger
Propane stove
Looking for a thread or some info on how to set up my propane 2 burner cook top. We will be using 2 standard grill propane for now. We will mount the tanks in the undercarriage below the sink and stove. Would a regular lp hose work? The hose wouldn't be exposed to any outside harm. Any and all advice welcome.
theradiumdial is offline   Reply With Quote
Old 03-27-2017, 05:05 PM   #2
Year: 1985
Engine: 9.0L v8 IHC
Sorry for the mistake on subject. It is actually a 2 burner cooktop not stove
Old 03-27-2017, 05:51 PM   #3
Robin97396's Avatar
Someone was just discussed this propane rubber hose issue a few days ago. Some use a rubber hose with grommets to reduce chafing of the hose from where it passes through the floor. Others prefer a standard residential hardline under the floor to several ports inside the bus through the floor.
Small propane heaters and camp stoves have small pressure regulators on each appliance. That means you have to bringing a high pressure line inside the bus with you probably leading to a manifold to feed several appliances.
Permanent propane appliances won't have those small regulators on them and would need the regulator to be mounted outside to support the low pressure side of the system. Consider that RVs have the pressure regulator on the tank outside, and only low pressure lines go inside the living area.
Obviously be very careful using a rubber hose as a high pressure line inside your bus. Sorry for being long winded, but I've had accidents with propane.
Robin
Nobody's Business
Old 03-27-2017, 05:53 PM   #4
Robin97396's Avatar
That's even better. The more you hook it up like a residential gas system, the better off you'll be, safety wise.
Robin
Nobody's Business
Old 03-27-2017, 08:18 PM   #5
Year: 1985
Engine: 9.0L v8 IHC
Thanks Robin for your input, I found a pretty good one here http://www.skoolie.net/forums/f10/ho...lines-519.html
Still lots of research to do, do not want to explode gain down the road...
Old 03-27-2017, 08:41 PM   #6
Robin97396's Avatar
That was better than what I heard in the previous discussion.
Robin
Nobody's Business
