Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-27-2021, 12:02 AM   #1
lcm0027's Avatar
Rear Engine Heater Lines Loop Install
I temporarily want to run a loop on the heater cooling lines while we rerun the heater lines under the bus. We are keeping the 2 heaters in the front (under driver seat and defrost) so to help with cooling in hot climates. Do I just need to loop the hoses together before or after the pump that they run to? Please see picture for reference and my poorly drawn lines.
Also the valve in the picture doesnít seem to close all the way. These valves I believe are already turned off but I think itís open a bit and coolant is still able to flow in that circuit. Is that normal?
The main valve I see on top of the engine is turned all the way off.
lcm0027 is offline   Reply With Quote
