Old 04-22-2020, 03:20 PM   #21
Coachwork: Eldorado (REV)
Chassis: Chevy Express Cutaway g3500
Engine: Turbo diesel 6.5L
I removed my rear ac and heat units. I plan to put in a mini split. Are you going to do a video of how you do it? Or are you following someone else's instructions? Or do you already have experience doing this? I have a son with electrical experience and training, but he doesn't have much time. So I want to see if I can do this with a little help or if I need to pay someone to do it for me.
Sharee100 is offline   Reply With Quote
Old 04-23-2020, 07:06 AM   #22
Coachwork: Metrotrans
Engine: T444e
Rated Cap: 23440Lb 31pass
I have compressor and brackets and some switches from my 1999 T444e if you need them .
49roadie is offline   Reply With Quote
Old 04-23-2020, 07:08 AM   #23
Engine: T444e
Magnakansas Bus nut ! or anyone else . I have compressor and brackets and some switches from my 1999 T444e if you need them .
Old 04-23-2020, 07:53 AM   #24
I totally missed the rest of this thread.. I definitely need brackets for a T-444E..
the dual-compressor setup brackets are what I need the most.. like the ones the original post refers to, i have a single system now but the bus needs a second one for the front.
Old 04-23-2020, 08:28 AM   #25
Chris you been wanting those brackets a long time!
Old 04-26-2020, 09:35 AM   #26
Chassis: Crown?
Engine: International 444e
Rated Cap: It is an 8 window handica
Interested in ac if still available
I have 2 units in my bus and only one makes cold air . I intend to keep both .
Mblackm1 is offline   Reply With Quote
Old 04-26-2020, 10:16 AM   #27
those with the brackets and pulleys how can I get them?
Old 04-27-2020, 06:22 AM   #28
Engine: T444e
The bracket of my T444e is on the shelf but the pulley is still on the engine , if you are interested i will try to take it of .
Old 04-27-2020, 06:27 AM   #29
im definitely interested!.. on mine the pulley just bolts to the existing engine pulley and comes off without interfering with the serp belt. .. not sure how yours is.. some are different.. snap a pic of it if you get a chance and we can go from there..
if we werent in the midst of Covid id prob be in FL right now...
Old 04-27-2020, 06:30 AM   #30
Engine: T444e
ok . I will look and take some pic,s today . I,m in no hurry so if this is what you want, you can have it any time .
Old 04-27-2020, 07:42 AM   #31
Coachwork: Girardian Handicapped Commercial
Chassis: E-450
Engine: Ford 7.3L
Rated Cap: 9,000
When you removed the freon lines from the air conditioner its self did anything come out? I want to rotate my AC unit instead of being in center facing front, turn it 45 degrees to face side to side. I need to remove the one line coming up the passenger side rear corner floor, reroute it under neath and fish it up the driver side rear corner with other line in order to get enough slack for the new location. If I have to recharge the system its not that big of a deal but I was hoping I could just remove it and not having liquid coming out or create air in the line and make the AC malfunction somehow down the road. Thank you
mc11237 is offline   Reply With Quote
Old 04-27-2020, 08:39 AM   #32
if your A/C works (and even if it doesnt). that refrigerant is under high pressure and can injur you if you just recklessly take the line off.. on a warm day sitting still its likely 80-90 PSI of pressure in those lines.. mixed with oil too..
if you want to take it apart you need to have the unit recovered at a shop.. move your line, then have it vacuum evacuated and recharged..
also you can turn your unit sideways however make sure that its not tilted differently than it was as they have drain lines for the water condensate.. if you tilt it one direction or the other too much the unit wont drain and the water will drip inside the bus..
Old 04-27-2020, 08:46 AM   #33
Chassis: E-450
Engine: Ford 7.3L
Rated Cap: 9,000
Wow, great info. I never thought about having to keep the same tilt too. Thank you. So I'm thinking of buying something like this
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Is this what I need?
Old 04-27-2020, 05:20 PM   #34
Engine: T444e
how do i post or send pic,s ??
Old 04-27-2020, 05:33 PM   #35
Engine: T444e
got the pully on the damper of and the tensioner pully w/bracket and a idler pully w/bracket
got the compressor bracket and compressor and som resistor and switches . dont know how to post pic,s on this forum . can I text or message them to you ??
Old 04-28-2020, 05:28 PM   #36
Engine: T444e
/Users/RuneRolfsen/Pictures/Photos Library.photoslibrary/resources/derivatives/3/3C8E44F8-12F2-4825-902A-FD4F130B888C_1_105_c.jpeg
/Users/RuneRolfsen/Pictures/Photos Library.photoslibrary/resources/derivatives/9/9868160C-ACAA-4BF9-97BE-1EDD8313CFB9_1_105_c.jpeg
/Users/RuneRolfsen/Pictures/Photos Library.photoslibrary/resources/derivatives/6/6179A422-FF22-4201-BE4D-8E5765706892_1_105_c.jpeg
/Users/RuneRolfsen/Pictures/Photos Library.photoslibrary/resources/derivatives/6/64E24CAF-419B-4662-BF25-D5348A9EE3DB_1_105_c.jpeg
/Users/RuneRolfsen/Pictures/Photos Library.photoslibrary/resources/derivatives/C/C8FF23AC-C260-41D1-A158-BBB73ECC04D4_1_105_c.jpeg
ac parts
