04-11-2020, 10:12 PM
Chassis: Shorty 6 window handicap
Engine: Int 444e
Rated Cap: 21
Removing rear ac unit
Hey All,
Next week I plan on removing my rear AC unit from my bus in order to install a mini split system. That includes the condenser, hoses and compressor as well. In Dallas area if anyone is needing parts. I haven't decided if I will keep the compressor as a spare yet though.
04-11-2020, 10:32 PM
It pains me to see folks taking road a/c out of their buses when I am looking at $2k-$3k to add it to mine.
Consider how you will be using it and how heat tolerant you are. I-40 through Northern Arizona in August is Hell without good road a/c.
04-11-2020, 11:01 PM
Engine: Int 444e
Rated Cap: 21
Well, I have a front and rear unit in only a 14' space. It pains me to think I won't have AC when my bus is parked with the engine off so it's adios muchacho to the rear unit...
04-11-2020, 11:05 PM
Engine: 8.3 Cummins ISC
Rated Cap: 75
All you people down south really need that beefy road going AC....I took mine out since both compressors were shot and it isn't super necessary in Wisconsin where it rarely gets above 80 degrees especially in the areas I travel/camp in.
04-12-2020, 10:00 AM
by taking that out you very well may also break the dashboard air conditoner as well, esp if you take out the underneath condensor.. those systems are most often tied together.. if you want the dashboard air conditioner to work you will likely need to take the T fittings out of the lines and add a new condensor to the front, unless you leave the underneath condensor and re-fit the lines you take out of that rear unit..
04-12-2020, 02:39 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Kcblkeeley
What do you want for the equipment that you are removing? I have a 1954 ford/wayne and would like to install a rear air unit like you are removing....? I am in Topeka Kansas, but I have a close friend in the Dallas area that I can send. My engine is a cummins so, none of the engine brackets will work for me. But I am very much interested in what you are removing. I am interested in the compressor but completely understand wanting to keep a back up. I assume you have a side skirt mount condensor system. for the rear unit and a condensor up front for the dash?
william
04-12-2020, 03:35 PM
Engine: Int 444e
Rated Cap: 21
AC info
The 2 AC systems I have are completely independent of one another. There is no common connection at all. As for price, I am not asking for anything. Even the compressor has it's own belt and brackets are mounted on top of the engine. I could use some of the space the condenser takes up as well.
04-12-2020, 03:38 PM
Engine: Int 444e
Rated Cap: 21
Cadillackid. There is no dash AC in My bus. They are both the same type of roof unit. As a matter of fact, the pic I posted was of the front unit.
04-12-2020, 03:40 PM
Engine: Int 444e
Rated Cap: 21
Both condensors are mounted under the skirt.
04-12-2020, 03:46 PM
Engine: Int 444e
Rated Cap: 21
William...
Plan on taking it out next saturday. If everything goes as planned I will message you with what is available to see if you could use it.
04-15-2020, 06:28 PM
Engine: Int 444e
Rated Cap: 21
AC parts available
Just finished removing my rear AC unit. Complete system including compressor, brackets, evap unit, condenser, hoses and wiring.
What parts do you need? I am near Dallas, Tx
04-18-2020, 01:48 AM
Year: 1954
Coachwork: wayne
I just saw that you pulled this system..
Do you know what kind of refrigerant this was intended to use? The skirt mount condensor, would you please tell me length and width? would you please take a close up of any numbers or tags that are on the compressor? You said earlier that you were going to keep the compressor.... I think, since I have a cummins I will not be able to use any of the brackets you have for the compresor. and yes I am very much interested.....
thank you
william 785 207 7600 topeka kansas
04-18-2020, 08:12 AM
Engine: Int 444e
Rated Cap: 21
Size and specs
William,
The condenser is 39 by 23 by 16 deep.
The freon is 134a
You can have the compressor if you want as well. As for the bracket, it was bolted on top of another compressor bracket, not the engine. And it has a built in tension pulley.
Buddy
04-18-2020, 08:38 AM
im looking for a "2nd" compressor bracket / idler for a T-444E... I have a single compressor and bracket on now.. did it use a bolt-on second pulley at the engine?
I want to add a dashboard air conditioner.. I dont need the compressor just the bracketry pieces to add a second one.
04-18-2020, 09:02 AM
Engine: Int 444e
Rated Cap: 21
Ac bracket
It bolted directly on top of the lower compressor. The bracket has a tension arm as well.
04-18-2020, 09:11 AM
thats the pieces i need right there!!..
where did the belt go? down to a secondary groove on the engine? or did it wrap around the first compressor?
04-18-2020, 09:48 AM
Engine: Int 444e
Rated Cap: 21
Pelley
Only went around an empty balance groove, compressor and the tensioner/ idler
04-18-2020, 10:39 AM
Yeppers I know exactly what that is. Looks like a Trans / AIR bracket.. it’s the set I need.
04-18-2020, 04:12 PM
Engine: Int 444e
Rated Cap: 21
Brackets
Cadillac, how do you get them from here
Buddy?
04-18-2020, 06:02 PM
Year: 1954
Coachwork: wayne
Kcbl
yes yes yes, pretty please. I telephoned and left you a message, I will try again later. I would like the compressor too, but, If cadillac can use the compressor, with those compressor brackets, keep that stuff for him.
I would like to use any hoses, wires, controls that came off that you are going to discard. that is provided it is still available.
thank you
william
