Originally Posted by budbud7
Well today was the first time I tried my heater. I didn't get the rear heater to come on. Didn't do any trouble shooting since I had company today. But for starters, I have only 3 switches for the system. 2 of the switches turned on the front heater/def and the other for the booster pump. Does anyone know if one or both switches should activate the rear heater? I know for sure that there are 2 fans in the front heater and each one will come on with one of the switches. By the way this is a 1999 Thomas RE. Thanks
You have the same model of bus as me, but mine has four passenger heaters. Two right at the back, two arranged down the side and the front heater and defroster. All have separate switches plus the pump switch.
Was your rear heater getting warm. It would get quite hot even if it wasn't blowing hot air just from the coolant flowing through it. Unless you are actually driving, it does take a while to heat up.
Next check would be to see if power is reaching the fan motor with the switches in various positions.
