Originally Posted by Iceni John
When I installed my Pioneer 12K in my Crown I used the bracket as-is: it seems adequate for the task in a moving vehicle. The unit hangs off the top tabs and is secured by the bottom tabs. I did however spend some time and effort making the mounts for the bracket that attach it to the side wall above the window, just below the ceiling - I drilled and tapped 1/4"-20 holes in the 3/8"-thick steel above the windows for the two aluminum spacers that hold the bracket vertical against the non-vertical body side, and some more threaded holes above the wiring conduits for the upper spacer bolts that prevent outward sway. I think it's going to work just fine this way, but I'll keep an eye on it to be sure. Besides, don't all Crowns ride so smoooothly anyway?
Same here. Mine is a different brand but they all appear to be built about the same.
I have it mounted on the rear driver side of the (fiberglass) bus wall. I built a sturdy shelf of 3/4" plywood held in place by two shelf brackets screwed to the wall; then I mounted the split system metal backer bracket to a plywood backer which is secured to that wall shelf by way of two
inverted shelf brackets.
Each bracket holds almost my entire body weight, so I'm feeling like it should hold, but will be monitoring it. Plenty of room behind for plumbing and wiring; and plenty of air circulation above.
