Old 08-22-2023, 10:21 AM   #1
Chassis: DT444
Engine: 7.3
Sizing a mini split
I have a 30' bus and looking for a mini split, my question is 9000 BTU or 12,000 BTU what would recommend for a Florida bus.
Fishfry is offline   Reply With Quote
Old 08-22-2023, 10:39 AM   #2
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
12000, no question. Better to have extra cooling capacity and not need it, than need it and not have it. My largely factory insulated 35' bus in Ohio can stay comfortable with a 12000 BTU in the back but the front gets a little stuffy.
dbsoundman is offline   Reply With Quote
Old 08-22-2023, 10:48 AM   #3
Chassis: Ford E450
Engine: V10 Gas
12K, no question, agreed.
Old 08-22-2023, 12:01 PM   #4
definitely 12000.. unlike a conventional; A/C that are easily Oversized. (and wont pull out the humidity).. a minisplit being variable speed variable refrigerant flow is really hard to oversize.. in fact you want them to be a bit oversized. as a minisplit runs most efficient in relation to its heat exchanger capacities. as about 80% of rated and less..
the only time you really take concern of oversizing a minisplit is if you plan to routinely require less than the unit's minimum output..
Old 09-29-2023, 03:09 PM   #5
Dual mini split?
I have a full size international CE300 Dog nose. I want to be cool while driving and then cool sleeping at night. I was not planning on having 220 in my skoolie just run one air handler at a time. Thoughts?
KrazyKarl is offline   Reply With Quote
Old 09-29-2023, 05:11 PM   #6
best way to achieve that is buy a bus with factory air conditioning... use that for on the road.. usually most full size busses have 2 systems.. you can remove the rear one and install a 120 volt 12k BTU minisplit for sleeping at night..
you keep the front factory bus A/C system for driving during the day..
many busses come with bulkhead units that can be located out of the way in the front bulkhead area so as to not be a head banger or sidemount that interferes with the conversion..
