Old 05-22-2020, 03:57 PM   #1
Coachwork: Midbus
Chassis: Chevy 6 Window
Engine: 6.6L DURAMAX LMM
Sub Floor Framing Question
Laying down 80 mil butyl and foil thermo-acoustic sound dampener over the sheet metal on the floor. I was originally thinking of laying down the sub-floor framing directly on top of the finished sheet metal with adhesive and screws and then place the sound mat in between the framing
I've had a thought now, though, that it might be better to lay the sound mat down over the entirety of the floor and then build the sub-floor on top of it.
Would there be any significant gain in sound/heat dampening from this extra step?
Would there be any problems with the structure of the sub-floor built on top of the sound mat versus directly onto the floor?
I'll be using spray foam insulation throughout the bus if that information is relevant.
dog_and_ape is offline   Reply With Quote
Old 05-22-2020, 04:49 PM   #2
What's the PSI rating for the sound mat?
musigenesis is online now   Reply With Quote
Old 05-22-2020, 06:14 PM   #3
I searched format and came across several brands. I don’t think I see what this will accomplish on the floor. It might knock down vibrational noise on a bare sheet metal floor, but I think that the addition of foam insulation, wood frame and plywood screwed to the floor kind of makes that stuff moot.
Danjo is online now   Reply With Quote
Old 05-23-2020, 12:17 PM   #4
TheHubbardBus's Avatar
Our tentative plan is to spray foam the entire interior, floor included.
Not only will it cost exactly the same as if we just did walls & ceiling (company we've chosen has a minimum square foot limit we're under even w/ the floor included), it should also provide significant sound deadening & it serves as its own vapor barrier.
If we weren't foaming the roof & walls, it might not be so cut & dried. But since we are, doing the floor at the same time seems to be a no-brainer. Nothing compares in the ability to kill so many birds (thermal/sound/vapor) with a single stone.
Old 06-04-2020, 12:31 PM   #5
wrenchtech's Avatar
Year: 2008
Chassis: Saf-T-Liner HDX
Engine: CAT C7 300hp w/retarder
Rated Cap: 46 + 1 36,200 lbs
Originally Posted by TheHubbardBus View Post
...Nothing compares in the ability to kill so many birds (thermal/sound/vapor) with a single stone.
Makes a lot of sense to me.
wrenchtech is offline   Reply With Quote
