Buy a pickup on Amazon.
Remove the fuel pump and gauge sender assy.
Drill the tank, removing all metal particles as you drill and with a spoon under the hole as you break through to catch particles.
Install the pickup ensuring that the bottom of the tube is far enough off the bottom that you can't exhaust your fuel while using the heater.
You may need an aux pump or even small aux tank as the pupms in the heaters aren't intended to pull a long distance.
There are detailed instructions in other threads. Ross did a YouTube as well.
