Old 03-26-2018, 12:36 PM   #1
trinitysj's Avatar
Chassis: TCFE2000
Engine: 5.9L Cummings 12v
Thermostat on Rooftop AC
Hello gurus.
I have a question. I have seen the Coleman Mach(?) system working with a regular wall mount thermostat.
I have been researching and wanted to know of the collective heads here if it is possible to put a Dometic Brisk Air 1 model and a Honeywell thermostat together and how that might be done.
I have attached a couple images from the Dometic and a sample honeywell that I was thinking of...
Thanks in advance.
File Type: jpg honeywell-focuspro-5000-wiring-diagram-agnitum-of-honeywell-focuspro-5000-wiring-diagram.jpg (38.2 KB, 6 views)
trinitysj is offline   Reply With Quote
Old 03-26-2018, 01:19 PM   #2
Jdawgsfanasty's Avatar
Originally Posted by trinitysj View Post
Hello gurus.
Thanks in advance.
If there's connections for a external thermostat it would work...
Jdawgsfanasty is offline   Reply With Quote
Old 03-27-2018, 09:41 AM   #3
Year: 90
Chassis: international
Actually, maybe not. The real issue here is operating voltage for the thermostat. Most house thermostats work off of 24 dc volts. some rv ac runs off 12 dc volts. As long as the thermostat circuit on the ac and thermostat are the same it will work.
Old 03-27-2018, 10:58 AM   #4
I recently installed a wall thermostat made specifically for RV a/c's. Worked great.
You may want to take a look at https://www.amazon.com/dp/B004RCOU9Y...a-378949341804
