Old 05-21-2020, 01:59 AM   #1
Coachwork: Thomas 4-Window
Chassis: 2003 Ford E350
Rated Cap: 6
Where to mount mini-split outdoor unit?
I'm in the planning phase for HVAC in my 4-window Thomas (E350 chassis).
I'm leaning toward a 9000btu Pioneer 115v mini-split running on shore power/generator and looking for ideas on where to mount the outdoor unit (33" long, 23" tall, 14" wide). I'd like to avoid the roof as I don't want anything taller than the solar array (even on the edge of the bus, it would add at least another foot in overall height). Right now I'm looking at either mounting next to the back door on a bumper-mounted bracket or underneath the bus (drivers side, rear). Under the bus would mean recessing it 6 inches or so into a "tubbed" floor and making sure there is plenty of ventilation so the fan has sufficient draw. I like under the bus for protection, security, and aesthetic reasons. I like the bumper mount for simplicity. The roof would offer air flow (and reasonable security) at the expense of height. Any other mounting ideas? Any other options I should consider beyond the mini-split (need very efficient heat and A/C as I'd eventually like to build out solar/battery well enough to run it)?
FatBoySTL is offline   Reply With Quote
Old 05-22-2020, 10:24 AM   #2
Year: 2012
Coachwork: Goshen
Chassis: E450
Engine: V10
Rated Cap: 1 1/2 ton
Thumbs up My Vote For Mounting a Mini-Split
Hi. On my Freightliner I went with the popular add a platform to the back.
There are several reasons I decided to go this direction.
I plan on installing, and already bought, two mini-splits.
After the 4 foot add on is complete including lights I plan on mounting the outside units in parallel, towards the outsides with the air blowing out from the middle.
Another reason I like this is I hope to put a roof over this addition and make it into a little porch like I've seen others do. With a railing around the outside the units will have some protection as well as conceal them just a bit.
Someone pointed out the very end of my new addition might scrape the road when going up a steep place, like into an uphill driveway. I'm planning on addressing that with the wheels used to stop a fifth wheel from scraping.
A significant concern, and one I've spent minimal time on, is finding out where to get the plastic air conditioning tubing like the bus uses for the built in air conditioners instead of the copper tubing that came with the units.
After adding the handicap bathroom and shower I plan on the maiden voyage. This first run probably won't be for a too long time.
GaryTheRock is offline   Reply With Quote
Old 05-22-2020, 11:08 AM   #3
Chassis: GMC Savana 3500
Engine: 6.5 L 395 CID V8 Diesel
im mulling over a similar decision I bought a pioneer 12k btu 21.5 seer. I have a similar bus to yours just a five widow gmc chassis. my bus only has 18' of clearance from bottom of skirt to underside of floor idk how much you have but would seem like you would need a much larger recess into the floor to get it to fit let alone not hinder airflow. running a mini split off solar for extended periods is not a easy task and will require substantial funds and since your bus is so small pretty much your entire roof would need to be a solar panel . I had the day dream of being solar only but when I priced out the system required I would of spent over three times if not 4 times what I bought my bus for on a solar system
waxman is online now   Reply With Quote
