Originally Posted by Bert06840
Even if you have to get a larger (say 12kBTU unit) that’s twice as efficient, you’ll run it only a fraction of the time.
I did not think about that. Thanks. The area it needs to cool is only 7' x 7' and about 4 or 5 feet tall. So even a 5,000 btu unit is overkill.
But, if a larger one runs less and uses less power....
This is going in a small sleeping compartment in the chase van. It only has 600 watts of solar and a 280Ah LiFePo4 battery.
The plans are to run it when needed off the generator. And maybe 10 or 15 minutes off solar when absolutely necessary from time to time.
