Old 06-19-2024, 05:33 PM   #1
Chassis: international
Engine: t444e
Rated Cap: short
Dash screen
Just a small 8" touch screen for my gauge pod. I have it mounted to the steering column so it moves up and down with it. I will mount a larger touch screen off to the right by the door handle for navigation/ entertainment. I will be using a thinkcentre m900 with Driveline frontend. It can do up to 4 cameras and voice activated.I will have a 400 watt amp for music and movies.
syntaxterror is offline   Reply With Quote
Old 06-19-2024, 05:43 PM   #2
Engine: t444e
Rated Cap: short
I forgot to add the picture.
Old 06-19-2024, 06:43 PM   #3
cool stuff!!! you know im allabout digital dash stuff
Old 06-19-2024, 07:46 PM   #4
Engine: t444e
Rated Cap: short
Thanks cadillackid.
I know you do a lot of work out on the road. Is it worth trying to get a mobile broadband card or just connect to my phone?
Old 06-19-2024, 08:11 PM   #5
Thanks cadillackid.
my screens connect to the Mikrotik router i have set up.. I have one in each bus.. one has AT&T and Tmobile wit ha failover and the redbyrd has just tmobile.. in that bus im using a newer Quectel modem (RM520) that supports all the current bands and 5G.. uses 4 antennas.. it works really well except in extreme remote areas... being my tablets are windows.. my biggest issue is GPS integration.. trying to find GPS software and USB GPS receivers that integrate is near impossible these days.. everything is iOS or android based for navigation.
my RM520 on the MT supports NMEA outbut on a virtual Serial port.. so I tried using the Tibbo driver to a com port to retrieve it.. that works but google maps doesnt recognize there is a GPS present..
Old 06-20-2024, 02:52 PM   #6
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
My tablet setup for my dash (work in progress) are all cheap Android devices that connect to the bus' "house wifi" which uses a Fortigate device that has both AT&T and Google Fi (Tmobile) LTE failover. I havent' sprung the $ yet to upgrade it to 5G capable. I have a post about the setup on my build thread.
So much easier than turning my hotspot on each time and killing the battery on my phone and I can flip priority at any given time between AT&T/Tmobile depending on my data usage
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
Old 07-03-2024, 10:25 AM   #7
Engine: t444e
Rated Cap: short
Has anyone tried running bluestacks and the waze app on windows?
https://www.bluestacks.com/campaign/com.waze/en/
