Old 03-30-2020, 09:04 AM   #1
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Getting Signal - Antennas, boosters, and masts
Hey there!
I'm currently searching for good solutions to long-range WiFi and Cellular broadband. I'm talking roof-mounted equipment, be it to the roof itself or on a (retractable) mast.
Anyone here with experience with such stuff, let me know what you use.
kazetsukai is offline   Reply With Quote
Old 03-30-2020, 11:10 AM   #2
You may also want to check out CruisersForum (https://www.cruisersforum.com/) as they deal with this issue a lot too. When I lived on my sailboat, I tried getting a WiFi signal booster to pick up the free wifi at a cafe near the marina, but I gave up because everything I looked at didn't amplify any signals, it was just a wifi repeater that required the unit to be within wifi range.
TheArgobus is offline   Reply With Quote
Old 03-30-2020, 12:13 PM   #3
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
In the case of cellular, height makes a huge difference. I went with the weBoost Connect 4G-X setup and am happy with it. However; I am pushing the limits. One of their "Drive" products may be better for most folks.
I had a fairly cheap wifi amplifier a couple years ago but I wasn't typically in places where there were open wifi signals so I gave up on that.
GO STARLINK!!!!
JD - Full timer out west
My Adventures & Build
Old 04-05-2020, 03:34 PM   #4
TheHubbardBus's Avatar
Coachwork: IC
Chassis: CE300
Engine: t444e
Rated Cap: 24
Yet to implement, but our staged plan is as follows:
Stage 1: Rooftop-mounted omni-directional wifi antenna compatible with our service, connected via n-connector bulkhead fitting through the roof. This is something that can be operated constantly, including while we drive. Already high because it's a bus, with a great ground plane because... it's a bus. Normally I'd rather use an nmo mount for going through the roof, but there are 2 reasons I'm going with the n bulkhead. 1: it will be easier to run larger diameter lower-loss coax to it from the inside, which I want to do to minimize loss @ the relatively high frequencies needed (plan to use LMR400), and the n-connector will make it easy to replace the rooftop antenna with a jumper cable to a mast-mounted antenna (see stage 2).
Stage 2: When we're parked, I'd like to have a mast mount on the roof of the bus, so I could get an antenna up even higher than the bus roof if needed, to clear trees / obstructions & otherwise improve line-of-sight performance. I'd run coax to any mast-mounted antenna by simply removing the aforementioned wifi antenna & screwing a length of coax between that & the mast-mounted antenna. If all I'm trying to do is get better wifi (in an omnidirectional pattern), then I just unscrew the wifi antenna from the roof, put it on the end of the mast instead, and jumper between its location on the mast to where it used to be.
Stage 3: If mast-mounted omnidirectional wifi doesn't cut it where we want to go, adding a directional wifi antenna (yagi) at the top of the mast instead of the omnidirectional to target specific repeaters.
Stage 4: If still needed after everything else, a signal booster like JD mentioned.
Here's the omnidirectional antenna we're going with. Big fan of Pulse/Larsen products, the n-male option just sweetened the pot:
https://www.arcantenna.com/m2m-anten...02700-mhz.html
I've got what plants crave.
Old 04-05-2020, 03:53 PM   #5
kazetsukai's Avatar
Rated Cap: 76
I've been leaning towards a couple of yagi antennas for ethernet/4g on a mast mounted at the rear. The one thing I haven't figured out there is cable management. If the mast extends to 30', 40', I need at least that much weatherproof antenna/ethernet cable wound up somewhere. Just don't want it to be a pain to manage.
The packaged solutions seem to work okay, but not miracles. For miracles, seems like you need to DIY.
