Old 07-08-2022, 12:32 PM   #141
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Engine: DT466e 7.6L 245hp | Allison 3000PTS
The maritime offering right now has to be setup for commerical use, although why they didn't label it "business" or "commerical" I don't know. Higher speeds (~300 Mbps), dual stations, etc. Designed for cruise ships, oil platforms, etc. And maybe Jeff Bezos' yacht (did he ever get that bridge moved?? lol)
Dbacks2k4 is offline   Reply With Quote
Old 07-08-2022, 02:09 PM   #142
TheHubbardBus's Avatar
Coachwork: IC
Chassis: CE300
Engine: t444e
Rated Cap: 24
OK, that makes more sense. Is that competitive with options available now (sattelite, I presume)? Or is it just so much better in terms of reliability / bandwidth it justifies increased cost?
My first wife was 'tarded. She's a pilot now.
Old 07-08-2022, 02:27 PM   #143
Dbacks2k4's Avatar
Year: 2006
I do IT infrastructure for my day job, a few of my clients are international but none have maritime networks, so can't really speak to it directly.
I would assume ships, oil rigs, etc would be using traditional satellite service so the latency has to be better on SL. All of starlink US Ground is ~20-60 ms and traditional satellite is 100+ ms latency, physics tells me that out to sea shouldn't be much different depending on how SL has their satellite orbits set?
One facebook post I read said his company had satellite on an oil rig and was paying close to $7500/month for <3 Mbps down and 0.3 Mbps up speeds. Have to take it with a grain of salt as it's another "expert" on FB but seems logical to me....
Old 07-19-2022, 06:26 AM   #144
turf's Avatar
Originally Posted by kazetsukai View Post
Like I mentioned earlier, I'm getting a second cable to cut. When I do that I'm going to try to do my own PoE injection with my own router. If it works out I'll post how we did it.
i came across a facebook group - "Starlink Hacks".
they have router delete instructions for making dishy run off POE. it looks like you can cut the ends off network interface, cross 2 wires and reatttach without the modem using a poe injector instead.
not sure, but i think my bt poe switch, should work as the injector.
Turfmobile Build Thread
Old 07-19-2022, 08:46 AM   #145
so i wonder if that allows you to use your own router and get the Public IP directly to your CPE?
connection, elon musk, satellite internet, starlink
