For the last 15 years or so the mikrotik routerboards have been my Swiss Army knife of internet routers. In the last few years they have even perfected their web GUI to be easier to use and more powerful.
At home or in the workplace they can be deployed in everything but the most demanding networks and much cheaper than even lower end consumer devices.
In my busses I use them extensively.. the LTAP mini in the dev bus provides a built in LTE modem along with a sim slot and a wired Ethernet connection. It also has a WiFi device in it which can be used to connect to public WiFi or to broadcast WiFi out.
This device has GPS in it as well so you can make a tracker out of it if you choose.
The WiFi on this model is only N grade however how fast do you need if your WAN is LTE..
This unit also has a serial port so if you wanted to log engine data and push it to a rs232 or you have say a solar inverted you need to talk to via serial it will act as ether to serial device or you can make a script to collect periodic data..
These have a very robust scripting language in which you can do about anything. The GPS tracker, arguably I stole some of the code off the internet for then made my own server and modified it to my own use . Anyway the tracker grabs the GPS coordinates and a script on the mikrotik posts them to my web server..
My ltap also gives me wired for my office phone which the milrotik completes an IPSec tunnel back to my NOC and the phone sees its mother ship. I make and receive calls and all my features work just like I was at an office desk. And without all the expensive software like Cisco requires for their remote phones.
There are many mikrotik models out there , you can even tether a usb hotspot and get WAN from it to a wired connection.
Who else plays mikrotik ??
Christopher
