Old 07-01-2022, 08:02 PM   #1
Engine: Cummins 8.3L
ABS Dash Indicator Light
We have a 2001 Bluebird TC2000 and the ABS Dash Indicator light is on. Where do I start for diagnosing the issue? Thanks.
crownstables is offline   Reply With Quote
Old 07-01-2022, 09:05 PM   #2
fo4imtippin's Avatar
Chassis: TC2000 28ft
Do you have a bendix controller? Mine is above my driveshaft and rear brake chambers. Below is the manual that explains what to look for.
https://drive.google.com/file/d/1-GB...w?usp=drivesdk
Old 07-02-2022, 07:50 PM   #3
ewo1's Avatar
In this thread, post #1, I uploaded lots of good info on antilock brakes. While it the info is from the Intl/Amtran service manual you might find some good troubleshooting info.
Old 07-02-2022, 10:13 PM   #4
Coachwork: International, Thomas
Engine: DT466E, International
Rated Cap: 72 passengers
ABS light on dash
Hi, simplest thing to start with is the wiring and check all your abs connections. Sometimes I've found that is a broken wire or a disconnected connection. The wires are multistrand but it's really small diameter wiring. I work some on semi trailer abs and sometimes it's the simplest thing that is the problem. Broken wiring, corrosion at the connections. It's not always the abs module. Just my 2 cents.
Dave1939 is offline   Reply With Quote
