Old 06-17-2024, 09:04 AM   #1
Hazards and turn signals not flashing
Iím having an issue with my 93í blue bird tc2000, Iíve removed (extremely carefully) all wireing for speakers, emergency exit switches, inside lights, a/c and heater units, when I tested to make sure my running lights, head lights ect. were working all came on but my hazards and turn signals were NOT flashing, I canít seem to find a fuse box, and thought maybe there is a flasher relay somewhere that is bad. Can anyone help me, I need to move from Florida to Illinois in two weeks.
Eric-Kracker is offline   Reply With Quote
Old 06-17-2024, 09:22 AM   #2
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Are they coming on and staying lit (e.g. on but not flashing) or not coming on at all?
If they're just not blinking there is a flasher module that should be in the fuse panel to outside of the drivers seat although I don't specifically recall where in there, it's been a while since I owned my old 97 Bluebird.
If they're not lighting up at all then it could be a variety of things, fuse in that same panel, a missing ground somewhere, shorted wire, etc...
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
Old 06-17-2024, 09:35 AM   #3
Thank you! I will look into the flasher module and double check the ground with the wiring.
