Old 02-14-2023, 02:38 PM   #1
Year: 93
Engine: DT 360
Rated Cap: 27000
Help identifying part for replacement
93 Thomas Navistar international 3600 with dt 360. Need help identifying these valves on the bottom of my air tank. Two of them are leaking so I'm of course loosing pressure unnecessarily. Anyone know what would be the proper part name or number to get some replacements. Doesn't look like there is any way to service or tighten them. They are not leaking at the exit port but instead around the actual valve workings on either side. Thanks in advance.
Michaelwnc is offline   Reply With Quote
Old 02-14-2023, 03:05 PM   #2
ewo1's Avatar
Simple petcock valves….
Old 02-14-2023, 03:19 PM   #3
Year: 93
Engine: DT 360
Rated Cap: 27000
Thanks ewo1! Is that something I could pick up at Napa? Are they generally standard size or should I remove one to take it in with me just to be sure? Thanks a million.
" Home is where the wheels stop rolling"
Old 02-14-2023, 03:39 PM   #4
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
Rated Cap: just the 2 of us
I'd take one....
BarnYardCamp is offline   Reply With Quote
Old 02-14-2023, 04:26 PM   #5
Year: 93
Engine: DT 360
Rated Cap: 27000
Will do, I figured as much but never hurts to ask. Thanks all.
Old 02-14-2023, 07:56 PM   #6
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Petcock drain valves. I replaced mine with a different variant to make draining water from my tanks easier.
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
