Old 12-21-2023, 09:49 PM   #1
Coachwork: Blue-Bird All American RE
Chassis: F204270
Engine: Cummins 8.3 ISC
HI all. RVI2 Braking system...
I purchased a used rig, which seems so far to be in working order.
I have an issue with the end of the breakaway switch.
If anybody knows what the male end socket for the cable is, which then plugs it into the side of the main unit. I would appreciate the info.
It looks like a standard barrel connector But I dont know what the size is to order.
Thanks
jfmusic@me.com is offline   Reply With Quote
Old 01-08-2024, 04:47 AM   #2
Yes, It's look like a barrel connector. It's kinda hard to tell by only looking at the screenshot. You can check the specifications of your switch online or on the manual. Some common sizes are 2.1mm x 5.5mm, 2.5mm x 5.5mm, and 3.5mm x 5.5mm. Or may be try to measure the diameter of the metal tip
willyuphere is offline   Reply With Quote
