Old 09-05-2023, 07:27 PM   #1
Engine: 6 cylinder diesel
Light stays on without hitting the brakea
Hey everyone. I recently bought a bluebird with the c7 engine. Iíve been driving across the country towards Montana Idaho area and thereís a light that Iím pretty sure has to do with the air brakes is staying on while Iím driving. I donít know much about the c7 and Iím in the middle of my move in eastern montana. Trying not to take it to a shop quite yet. Anyone know what it means?
fordthomas is offline   Reply With Quote
Old 09-06-2023, 12:25 AM   #2
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Dash looks to be around '04-06. That is the brake press light. Could be a bad brake switch or a shorted wire. Does the cruise control work?
BamaBus is offline   Reply With Quote
Old 09-06-2023, 09:37 AM   #3
The cruise control stopped working as well
Old 09-06-2023, 12:03 PM   #4
Chassis: TC/2000
Rated Cap: 1
The activated brake switch will cancel the cruise control when the pedal is pressed or in case of a bad switch. If the rear lights are lit up then vehicles behind you will not know when you are braking.
What year of bus (Vision?) is this? The parking brake is air but do you have hydraulic or air service brakes? You probably need to replace the brake switch when you get a chance.
Old 09-07-2023, 06:22 AM   #5
The lazy farmer's Avatar
Is it building enough air? What does the air gauge say?
If there is enough air try pulling up on the brake peddle.
Farmer, trucker, Scoutmaster for our local Boy Scout troop.
99 Freightliner Blue bird 53 passenger 5.9 Cummins AT 545 4 speed Allison 3:73 gears
The lazy farmer is offline   Reply With Quote
